Logger upgrades
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
I didn't get as much as it wanted to finished tonight. I sectioned a piece out of an old frame and fitted them to finish off my framerails.
Sucks getting home late from work when you have projects to work on.
Sent from my 0PJA2 using Tapatalk
GOOSE
Happy IDI'er
Well, she's sitting on all fours again. I have a laundry list of things to tighten up and a bumper to build now.
crash-harris
Breaker! Breaker!
Chillicothe, OH
Is this one of the OBS hangers?
And do you happen to have a link to the fabricator? I believe I had it before my phone decided to wipe all my bookmarks :rolleyes:
GOOSE
Happy IDI'er
Loving the tires. The running boards will be off in an hour or so. Too much rubbing.
no mufflers
rhode island
is it me or are the tires a lot closer to the back of the fender then the bumper. or are they supposed to be like that.
FarmerFrank
Blairsville, Pa
That's how my brick nose bronco looks with 35x12.50x16.5's
Put all new bushings thinking it was a radius arm problem. Still looks the same.
crash-harris
Breaker! Breaker!
Chillicothe, OH
That's the reason why most people move the axle center line forward about an inch when doing a solid axle swap. IIRC, V code springs will also do this. All the '96 and earlier springs have the center pin offset to the rear and the V codes are supposed to be more centered. People have also corrected this with zero rates. Sky Manufacturing is also making relocation plates now.
ntjapkes
