Go to
www.partsexpress.com and order up a couple of Bosch relay plug in pigtails and a few waterproof 30 amp bosch type relays and grab a handful of crimp on blade connectors and make yourself some replacments, and from then on, you will simply be able to plug in a standard bosh relay ( although I recomend the waterproof ones as that is what gets LMCs relays is moisture ) Fairly easy to wire up, , but if you have trouble figuring out the pins, PM me and I'll go down and see how they hook up ( im kind of busy these days so I'm not just jumping out there)
