Looks good, but why'd you order two orifice tubes? And I don't see a condenser on your list.
Be sure to get some AC flush and clean that evaporator out really good. PAG oil doesn't mix with R12's mineral oil so it's important to get it all out. If unable to remove all residue you use Ester oil in a conversion as it's compatible with both freons and oils.
The 2 orifice tubes was because I didn't open it up yet so I don't know whats in it. Also I have red were people have used red in place of a blue on 134 conversions.I talked to 4 seasons they said since I didn't have a compressor failure I would be fine with the old condenser. I have the flush. They make a nice flush tool that hooks up to shop air. I am trying to find a cheaper substitute. Anyone have an idea? http://www.nationaltoolwarehouse.com/AC-System-Flush-Kit-P26338C293.aspx
That's too bad the answer wasn't as easy as that. I wonder if the problem isn't with the blower but with an inefficient design of the air box itself, loosing the velocity created by the fan by the time it reaches the vents?
