led tail lights affect E4OD shifting.
F350crew
Seattle
1993 f350diesel E4OD with newly rebuilt Trans. Seems to shift randomly, Wants to skip 2nd and shift in and out of OD when cruising at highway speed. The transmission rebuilder thinks it’s the Led tail lights may be the issue. Do I add a resistor somehow or use a US Shift trans module?
chillman88
Central NY
Yes, you will need to add inline resistors. The brake light circuit causes issues with the E4OD when using LED lights. Very common issue.
RangerDanger
