Leaf spring bushings....
firehonomichl
Worland Wyoming
Well it’s that time fellas I gotta do leaf spring bushing... what is the consensus on rubber vs polyurethane? I want to do a solid front axle when I can afford to so idk if I want to sink a ton of cash into this set up but it needs to be done to hold me over..
Poly lasts longer but gives a rougher nosier ride. Everything is a compromise isn't it?
mblaney
Ottawa/Ont/Canada
I put poly in mine and the ride is just as rewarding...
Getting the old bushing out is a PITA but putting poly in is easy peasy. If you are doing rears, I would recommend replacing the whole spring.
u2slow
bilge rat
PNW
The shackles are one step - and you'd re-use those with a D60 unless going RSK. Another thought is if you re-bush the existing springs, you might be able to cut them out of the spring eyes for your D60 springs later.
Scotty4
I just did the energy suspension poly bushings in mine at the same time as new shocks. Ride is great. Talk about a pain though.
1mouse3
il
Removing the old bushing is not to bad, just perforate old the bushing so the core can be punched out and then take a saw of some sort to the outer sleeve. The hard part is dealing with a frozzen bolt if is the case that is 9 out of 10 what happens around salt, a big cut off disk works better than saw sawzall blades.
firehonomichl
Worland Wyoming
Thanks that’s good to know. I’ll be doing them and the pivot bushings this weekend.
When I went to install the new pivot bushings, I could not get them pounded in there. What I had to do was get some all thread, and some large washers and a metal cup, run the all thread through everything and then squeeze the new bushings in place by tightening the nuts on the all thread.
You can make a "cup" by using pieces from a balljoint press kit if you have one. Or if you happen to have a really large socket. The ID has to be large enough to let the bushing stick through.
olsen726
