Can30Diesel
Yeah I agree, I am not used to the truck not running out of breath half way through the pedal. The 4r100 does seem to do some gear hunting, and there was an issue with the 2001 transmission where a bad solenoid would cause the transmission to bounce around between gears and I think the OD light would start flashing. That was fixed in 2002. In my case the PO got a brand new transmission from ford with the appropriate upgrades and the shift kit. I think Ford also called for the upgraded trans cooler and the inline filer as well which I also got.
In your case, check the obvious like trans fluid color and level then go from there.
I have not had to change the drain on my filter housing so I am not sure on that one. I seem to recall reading that it doesn't have to come off but I could be wrong.
Another thing that is common with these trucks is the wiring harness for the injectors that goes under the valve covers. It wears out and causes codes and rough running. Mine was also replaced by the PO.
Overall these trucks and motors are sought after for good reason. They just work and work and work. Unless mine burns to the ground, I am not getting rid of it.
