Ataylor
Hi Everyone,
When I pulled my waterpump off, there was cavitation gouges in the plate that it bolts to. The gouges are not near to going through the plate as the plate is pretty thick. I wanted to "clean" up these divots so I applied JB-Weld with a razor blade to the spots. I have sanded with 400 grit dry. When sanding the spots, they got a little wet with coolant from the engine block and seemed to get a little soft. This was after letting it cure for 4 days. I looked at tthe JB-Weld website and it says it is impervious to oil and most other chemicals. I was able to run my thumb nail through it and make a slight dent.
I decided to let it set a day. I sanded it smooth today and it seems o.k. I just don't want that stuff to be floating around in my newly cleaned cooling system. I cleaned the divots with a wire brush and laquer thinner and let it dry completely (20 minutes) before applying the JB-Weld.
If it is not going to stick, I would rather wire brush it out and live with the divots than to have that stuff floating around in my cooling system.
What do you guys think?
Thanks for any input.
Archie Taylor
Archie Taylor
