ISO Flexplate Spacer
Justin B
Virginia
Good morning,
I have a cracked Flexplate on my 1990 F250, E4OD combo. It's of the two piece design, thin Flexplate mated to a cast iron flywheel/ring gear. I got excited when I found a replacement Flexplate for under $100, but now I've come to the realization that I need the elusive crankshaft spacer to make that method work.
Does anyone have a lead on the thin Flexplate for the two piece design, or more preferably, a lead on a crankshaft spacer to retrofit to the widely available one piece flexplates?
Thanks for any help you guys can provide!
What happened to the one that was on your truck when the flexplate cracked? You should just be able to reuse that one.
chillman88
Central NY
I think I stumbled upon the spacer on R&Ds website, but I'm not sure if that's the one you need or not. Just remember seeing it.
Justin B
Virginia
IDIBRONCO, not sure I follow your question. I don't have a spacer, rather, I have a heavy cast flywheel with a thick hub, flexplate is placed inside that and the whole assembly bolted to the crank.
chillman88, I stumbled across his yesterday in my search, that one would put a hurtin' on my fun money, but it does look like a long-term solution, especially for those making more power.
I did find my style flexplate on eBay, $85, looks like a reproduction, not Ford factory, I'll follow when it gets in next week.
Really? I thought those only came outwith a C6. I thought that the ones that need the spacer were for the E4OD.
Vern
Albert NB
‘92 E04d van
Va_Mike
Southeastern Virginia
If the one you ordered isn't correct, I am pretty sure I have that spacer sitting in a box of parts I pulled off a 1989 7.3 parts truck that had the E40D. I have a ZF5 so I have no need for it.
Justin B
Virginia
A follow up with good news, the plate came in and was a direct fit, seems to be of the same quality as the original, at least thickness and weight. Took me some time to get everything back together but it's in the truck and she's running good.
The ebay seller is wwwseautocom and the description for the plate is "FORD 7.3L,6.9L/ NONTURBO FLEXPLATE (33848) E40D, C6 DIESEL TRUCK OEM E3TZ-6A366A". I don't know if they'll have more, but might help someone else in the future.
