Is this Zf5 trans compatible?
Ryan Cowper
Redding CA
I have a 89 f250 7.3idi with the 4x4 zf5 transmission. I have a buddy with an 89 f250 v8 parts truck that has a recently rebuilt flywheel, transfer case and zf5 trans. Anyone know off hand if the gas flywheel, transmission and transfer case bolt straight in to my diesel?
nelstomlinson
Delta Junction AK
I have read on here that the 460 ZF5 is close enough you can make it work, with some drilling, but other gas ZF5s are not going to be modifiable.
It seems pretty likely that the transfer case will bolt right onto your ZF5. What kind is it?
I'm guessing that the gas flywheel is absolutely not going to fit the IDI.
