intake ideas
Mullis23
Mike
Loveland Co
since im n/a and still have the factor air cleaner i am trying to get a few ideas i looked at all the setups in the tech forum but i was thinking of taking a five inch elbow right to the intake manifold then running five inch exhuast tubing down behind the driver side headlight with a big conical filter on the end i was just wondering if it would work and if it would help any info would be great thanks
What your describing is what is known as a Ghost Tube. You need an air intake kit like this one for a 5.9L Dodge. Just drill the bolt hole a little larger and stick a bigger air filter on the end.
memphisrain
Calumet, MI
Would an intake hat like that work for a boosted application, or is it too cheap of metal to hold up to the boost?
Sorry for the thread hijack...
mR
tractorman86
Buckeye, AZ
i really dont think you could get a 5" elbow under your hood, even if you could you'd still have to get a bolt to seal down on it running through. i've got an aluminum one, it cost me 50 bucks. but i doubt it would hold any boost, it has kind of a crappy sealing surface. i had to slather a good bit of silicone on there to make it seal.
seawalkersee
It needs a turbo...
KCMO
Why not just throw an air cleaner on that thing from a gasser? I think you woulld be good to go with that....I will check with my spares tommarah to see if it will work.
SWS
CDX825
filtration nut
Litchfield,Ohio
You going to have to go pretty big with any conical to outflow the stock filter. The stock housing with the right element would be better IMHO.
Yes it does. I've never actually held one in my hands, so I don't want to comment on using it as an intake hat with a turbo.
Cat_Rebel
Does not compute
Wouldn't you like to know
You could make a setup like I had. I took a part of a late 99-03 7.3l powerstroke intake & put a PVC pipe on it to draw air & cut slots on the bottom to clear the AC line & help shead water.
Dropped EGTs about 100* so I didn't argue. :D
jpd78
minnesota
what diameter tube is it on the dodge intake? would a 6637 filter fit on it?
