Injector Washers
PossumTruck
Michigan
Does anyone know a source for/common size for the copper washers that seal the injectors?
I want to pull mine and inspect the tips/clean after a couple years of WMO. I don't think I have any issues, but I want to see what's been going on. Anyhow, I can only find those washers in a format that also comes with the return line kits. I don't need hose or caps, and I have a bunch of viton o-rings - thus, I would love to find a source of just the washers.
I have no idea how bad of an idea it is to reuse the washers, but I would rather not risk it if possible.
Here is another thread from 2021.
Looks like the washer size is...
.615 OD----MM 15.612
.298 ID-----MM 7.569.2
.058 Thick--MM 1.4732
90 - 02 Dodge Cummins
OD 15 MM
ID 7 MM
Thick 1.5 MM
Do your own research
morerunner
