jam sandwich
I'm leaking diesel out of my return lines, quite bad I might add.. It makes it start hard, and misfire upon startup.
I have a replacement return line kit already.. however I'm missing the injector line damper (the bracket that holds the hardlines together) on the left bank of the engine..
Is it possible that could be the cause of the leak? Is there any place that sells those fuel line brackets?
It's only leaking on that side also btw.
