Injector return line kit- where besides DIS to get one?
GaPchNCrm
Franklin Ga
I believe they keep this kit on eternal backorder. I NEED!!!!!!!!!!! this kit- yesterday. Any ideas on where else to get one? Preferably before I light a match under my truck. -cuss
pafixitman
Westminster, MD
Ordered yesterday at noon, on my door step today at noon.
http://www.shopdiesel.com/index.cfm/action/productdetail/product_id/495.htm
Worst case, PM me your addy and I will send you the one I just got. Mine is for a spare (never replaced them at Eric's or the most recent time I tore her apart) and I also ordered my 3.5" tail pipe from them so shipping was minimal to add this.
typ4
Newberg,OR
where is franklin in relation to atlanta? Any good diesel pump shop should have the kit. my2c
GaPchNCrm
Franklin Ga
Joe- THANKS! I ordered one from them, hopefully it will be here in short order and save my truck from a rather crispy fate.
Thanks for all the sites, I appreciate them!
SKimballC
Portland OR
I ordered a return kit from DIS a couple days ago and got the backordered indefinately reply. I canceled that order.
That shopdiesel site is mistaken about the 7.3 kit being for a Powerstoke. They are actually referring to the later IDI style caps with 1/4" hose. Tanya, that is the kit you need for your '93 NOT the 6.9 one.
pafixitman
Westminster, MD
The kit is from Stanadyne part # 36485. The label says "kit Nav 6.9/7.3"
The returns are in the center and not offset. I forget which is 6.9 versus 7.3
NJKen
is a daddy!
Central NJ
I second NAPA. They call it a fuel injector return line kit. The price is a little high compared to some of the online retailers but you should be able to get it quick.
Ken
SKimballC
Portland OR
The ones that are in the center are 3/16'' as found on 6.9's and early 7.3's. The offset ones are 1/4" as used from '91 and on IIRC.
Diesel JD
Gainesville, FL
Hey you can use either the 3/16" or the 1/4" IE the 6.9 or 7.3 kits are interchangeable just as long as you are consistent and don't mix parts. That is if you buy a 6.9 kit install everything, t-s, hoses o-rings, clamps everything except the copper gaskets. Don't even use them unless you pull the injectors.
Huh? I thought Parts America was gone. cookoo
Cv axle
