I can help you with either a GM govenor spring (4000 RPM) or a factory Ford one. However, I would suggest to you that your best option is to just get a reman pump of the correct model. Your current pump is probably already worn, and trying to do this stuff yourself is not a fun use of your time. Results are iffy at best, and you don't have this....
There's about 100 parts if you choose to take one apart, and they look like this....
I've taken quite a few apart. I've never put ANY together. I wouldn't want to, and knowing what really needs to be done to properly rebuild one of these. Almost every (about 29 out of 30) pumps needs to have the advance piston replaced, and the advance bore sleeved and dressed. I have much better things to do with my Saturday then sit in front of a jigsaw puzzle, and I do NOT like putting pumps on and off of trucks multiple times trying to solve issues (which I have had to do during the course of R&D). However, if you try and fail, you can send me your basket of parts and I can have it made into a whole pump for you again. Just don't loose that tiny little ball that's in there... (about 3/32" diameter) if it rolls out, you'll never know it, and never find it.
