Wvdirtroad
Here you can see the rigid line that Ford uses to feed fuel to the IP. What you have appears to be a non stock fittkng and I would be concerned about damage to IP if threaded in to far or hard.
Here I am pointint to the feed line from Filter head to IP
I am only GUESSING with this comment however I suspect that brass fitting you have has tapered pipe threads which is not the correct thread....juzt guessing mind you.
OH YA...I have several stock 7.3 Filter to IP lines in stck too btw...
Hope this helps clear up for you the issue we see.
That's definitely an issue then. The setup had the barbed fitting I showed above along with a rubber line running to the filter housing. Do you have both the solid line and the fittings that go with it? I'd like to get them back to the way they should be in this case.
