Wvdirtroad
Just received my rebuilt pump from Russ and it includes a pump kit which I didn't expect. I wanted to make sure I'm putting the parts in the right places- did a little searching but not a lot of luck.
1. The kit includes a large Oring, which I assume goes on the end of the pump that slides into the timing gear?
2. There are also 3 olives in the kit- can anyone verify the exact location these should be installed? I believe they are for the return line rail and so forth.
3. There's a smaller Oring as well, but I don't recall removing one from anywhere when I took the pump off.
I appreciate the help. I'm going to start getting this thing back together and see how it runs once I get my new injectors in.
