pedro_8149
7.3L Remote Turbo
Inj pump instal as we speak (UPDATE, ITS RUNNING BUT A COUPLE QUESTIONS")
So at the moment im doin my inj pump swap, got the old pump out and lines etc. while the inj lines are off id change the glow plugs considering there easy to acess and are factory ones. So do you all have any final tips for me while installing pump, tourque for the 3 8mm bolts and the 3 9/16 nuts on the back instal the pump with inj lines pre installed etc. andbiggest is i have to use my tps unit where do i check the power with a digital volt meter just tips to make instal smoother. Thanks now its time to head back outside and do some more tinkering. Ill check back in a bit. And yes i do have pics of everything out and what not.
