There is no idle adjustment on the PSD, it should idle about 700 rpm though. I think the manual tranny had a lower idle setting than the auto, 600 or something like that.
If he wanted to go with a custom chip he could specify a higher idle setting to be burned in.
dont know if its available for that make and model but some programmers will allow you to set the cruise while not moving. kinda like the ford rpm controlers for the pto systems. seems to work good on the ones i have seen
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
