Burt, I believe there is actually a "bi-metallic idle/advance compensator" inside the pump that is supposed to compensate for variations in fuel temperature and viscosity. That's the reason why all the trucks I've owned with a DB2 pump seem to idle higher when warm than when cold (once the high idle has kicked off, of course.)
My guess as to why it forces a higher idle when the fuel is warm is because warm fuel is less viscous than cold fuel, since there is no real physical seal on the distributor section of the pump (just a very precise machined fit) the pump causes slightly higher idle to compensate for more fuel leakage past the machined parts in the pump...
There's alot at play inside these pumps that can affect idle speed, really. As different parts wear differently the idle changes mostly because it is a static point of reference (since it is set by the idle set screw) whereas all other engine speeds are relative to the throttle cable position.
