IDI stuff and some gasser stuff
264WSM
Wyotana
I don't know if it is different or not. The truck is loaded with 3300 lbs and 11,060 gross. If need be I can bring the transfer case in March as that is light enough for my wife's Toyota to handle. I'm going to check on a spurious code, then pray and hope for an uneventful trip.
Mission is green lighted!!
I can meet Thurs/Fri/Sat. Leaving Sunday morning. Morning or daytime would be best as I will have plans in the evenings.
Knuckledragger
Payson, AZ
Good news!
I will drive up early Friday. Now I just need a location to meet, probably 9:30-10:00 am.
264WSM
Wyotana
Time to thin the lot.
7.3 IDI long block. Rebuildable core. $150
7.3 IDI Complete eng. Spins free, very tired. With ATS turbo $450 DELIVERED
6.9 IDI Complete eng. Runs OK. $200
ZF 5 speed trans from 7.3 4x4 with transfer case. Unknown history $350 DELIVERED
ZF 5 speed trans from 7.3D 4x4. Good core, 2nd gear needs sync. $150 DELIVERED
E4OD Auto trans from 7.3 4x4 with transfer case. Unknown history $350
C6 Auto trans from 6.9D. For 4x4. With transfer case. $300
Transfer case from ‘88 F-250 $100
Several F-250 axle sets. 1980’s, 3.55 and 4.10 gears $250/set
Body parts from 93 F-350 SRW 4 door, long box. Some rust $300 for all
5.8/351 Fuel inj engine. Complete. Unknown history. $75
300 6 cyl. Long block. Tired, but ran. $50
If I am out of line on prices, my feeling won't be hurt if you make an offer.
I'm in NW WY. About 40 miles N of Cody and 80 miles S of Billings. I will be going to Vegas in Jan and March. Normally we take my wife's Toyota at 40 mpg. If need be I can take the truck with some items in the back.
I can also be reached at 303 2 zero 4 - 3 two 82
Most of the remaining stuff is still in the vehicles. If you want it - I will need time to pull it. I also have a service box for a dually $800
264WSM
Wyotana
Knuckledragger and Gearhead4207, Thanx for meeting me in Jan. I had to cancel my March trip due to my mom's chem/radiation appts.
The truck with the 351 and a set of 4.10/4.11 gears is next to be disassembled and remaining parts sent to the crucher!!!
264WSM
Wyotana
93 truck with the AEOD4 next on the chopping block. This has the stuck long block in the bed with the heads off. I'm keeping the front axle - all else is up for grabs.
Pix of the 88 that needs a new home:
720Diesel
