well time for an update. today i got the motor,trans and t-case out of the frame...
i bought a 1500# engine stand from northern tool since my dad happened to be in the area... since i was by myself it took a bit to get the frame pulled around to my garage with my truck (4wheeler just wouldn't cut it) got the starter pulled...bell housing bolts removed....engine mount bolts....then i got the lift setup and tried to pull the engine. i fought with it for an hour trying to get the input shaft to release from the clutch disc. i guess it must have rusted a bit from sitting
the motor is that heavy that on the asphalt i couldn't pull the stand....so out came the 4 wheeler.... holy cow that idi is heavy!!!
after finally getting the trans unstuck and getting the engine away from the frame i started to mount the head for the stand (i removed the ford adapter plate for those wondering) turns out the bottom two arms are not long enough. so out came some 1/2" plate and the torch.
i had to make two adapter plates and cut down the barrel on the stand arm.
then while trying to move the stand it tipped over and the 7.3 crashed to the ground!!!! no pics of that though
so after another 45 minutes of using a digging iron to pry the lift over the speed bump in front of my garage and get it positioned so i could pick up my now grounded 7.3L i got it lifted again and onto the stand.
then i pulled the trans and t-case....now just laying in the frame
basically took me 3 1/2 - 4 hours but man i feel like i got my rear kicked..
