IDI powerstroke swap or cummins swap
superduty12v
CT
im lookin at buyin a 94 IDI, i dont know if its turbo or non turbo yet, but im wondering if i can swap a pstroke in there, if all the wiring will match up. the pstroke is a 96 engine. also, if i can swap a cummins in there. i know destroked has alot of adapter plates and whatnot but im just curious am i going to have to rewire the whole thing. i dont think i will with a 12 valve but im not sure. any help?
dyoung14
Is getting worn out
spencer,tn
No the psd is not a direct swap, there is alot of work involed,
ANd why on earth would you want to take the idi out? and out a psd or a cummins in?
There is nothing wrong with an idi they are great engines
coletrain777
Clark, Missouri
Powerstroke would be A LOT of wiring...
Cummins engine is a very common swap with aftermarket parts and support.
If you use a 12 valve Cummins you won't really have to rewire anything, if you want to use a 24 valve then that is a different story.
86F2506.9
6.9 International
Myerstown, PA
agreed i think theres alot more potential behind out idi motor which is why i dislike alot of people doing the cummstain swaps or puttin a powerstroke in one of our trucks these idi's are so reliable
rhkcommander
Oregon
reliable yes, but the recipes are out there for easy hp. None really for the idis sadly in comparison - prolly just not enough money invested as it is in the ps and cm crowds
Darrin Tosh
IDI Hound
Grand Rapids, Michigan
First of all,..Are you sure it is an IDI, because if it is a 5sp truck it may be a Powerstroke.
in 94 you could get the IDI non turbo, an IDI with a factory turbo, or a Powerstroke, but only with a 5sp trans.
If you wanted to do a Powerstroke conversion you would need a complete doner truck 95.5 to 97, You need to change out the complete dash, and all wiring, Radiator, gas pedal assembly, Computer, Etc. It will bolt in pretty easy.
For a Cummins, if you did a 12V, you could use all the stock wiring, and adapt it to the Cummins. You would need the adapters, and motor mounts, and depending on the trans you use, you may need an aftermarket 700.00 computer to run the E4OD. You will need to move the trans back and shorten the rear drive shaft, if it is a 4x4 you need to lengthen the front one as well.
I don't want to turn this into a Cummins VS IDI Debate, but I feel that I can defend your decision since I have had a lot of experience with BOTH setups, and most of the naysayers do not.
As far as Why you would want a Cummins instead of an IDI,... Well if you want to haul a 5th wheel camper 65 to 70, with the AC on, through the mountains, with no stress of overheating, or fuel temp issues, getting 30% Better fuel mileage, and having a motor that is known to go 500K miles, then it is a no brainer. But if you have a small camper, or don't haul a lot of stuff, and keep it under 60 MPH when you do haul, don't mind slowing down to 40 through he mountains, and want to do head gaskets every 150K miles, then keep the IDI.
I have said it before and I will say it again (toung in cheak) "The Cummins conversion saved my marriage!" Our trips are way less stressful! ;Really
superduty12v
CT
its a 94, IDI auto. and if i have to do all that to put a 12 valve in it im probably not going to do it. i was looking for a basic engine swap to gain a little extra power. im probably gonna end up throwin a sidewinder kit on and some new sticks in it. if i get it, thats probably it. this way i get a little better power and hopefully the fuel economy i get im my 24 valve. also should i go with head studs if i get this truck?
Diesel_brad
Dunce
gilbert pa
Plan on some head studs too for reliability
u2slow
bilge rat
Coastal BC
I absolutely love the simple VE-pumped, non-intercooled cummins in my 90 Dodges. I wish my Fords had that instead of the PSD. ;Really
I expect to be swapping in the future sometime.... not exactly sure if it will be a 6BT, but a mechanical inline engine regardless.
IDIs are fine.... much less BS than a PSD.
Exekiel69
If You still don't have the truck and are looking for a powerstroke or cummins why not buy one with th engine already in it?
That being said, the cummins is easier than the power stroke swap by far I believe.
Also You should keep in mind what Darrin posted already.
Diesel_brad
Dunce
gilbert pa
You dont need head studs with a 7.3, as long as boost is kept below 15psi there is no reason for them
It will be perfectly reliable
for you maybe but typically from what i have read the head gaskets dont last too long after a turbo was installed
Diesel_brad
Dunce
gilbert pa
To the OP. a powerstroke would actually be a direct bolt in IF you had a powerstroke donor. but you might as well buy a powerstroke then, it would be different if you already owned the truck but no point in buying a 93 and put a powerstroke in when you can go buy a 94-97 w a stroke in it
mabc926
Mojo
Hidden vally
If you want to swap in an engine, then swap in a Cummins, it's just easier, much less BS to deal with.
And Yes there is nothing wrong with the IDI's, but I'd rather see you swap in the engine you need and get out of the truck what you want, and then sell your IDI to someone that will use it for somthing that works for them.
I need to add this about the factory head gaskets. My passenger side head gasket lasted either 278,000 or 378,000 miles. I bought my truck with 34,000 miles on the gauge so I have no idea if it went around once... I really felt it had not and the 34,000 miles was correct... No dirt or arm rest wear at all. So the factory head gasket lasted the entire life of that 89 block. I cavitated number 5 cylinder and told the shop to replace the head gasket while the enigne was out... Nope.. They wouldn't do it....:eek: Said it was not needed... I really think they felt I would be back in a year to replace it because I tow heavy and the Banks sidewinder is set for 13 lbs of boost... Well they lost that money big time... They also feel the head bolts are enough to hold the heads in place... I don't and for the low cost I feel the added insurance is worth the issues on the install. ARP studs can be used almost forever. Once you torque them down and loosen them 5 times the friction is normalized and the torque will be as close as you can get it across all the 17 nuts per head. Thats a very important thing most fail to understand... That and having a torque wrench thats been claibrated yearly... The only wrench that does not need to be calibrated is the spring bar torque wrench but... Have you ever used one of those... Its usually a two man job... Studs are an added type of insurance for these engines... I believe they are a needed item on any 6.9 because of the 7/16 bolt diameter. Our 7.3 bolts are 1/2 inch and I had a new one tested to failure at a know testing lab that does lots of work for NASA around here... They broke at 153,000 psi..... ARP breaks at 200 or 220 thousand psi... DPS first sets broke at 270 thousands lbs... I had the first set but.... They didn't hold up in my second build. I found one in the driveway and another one on the motor mount... ARP saw them and had no idea why they broke... They were H13 material... I really like having 270,000 psi of added insurance but if they let go then they wont work for me. I really hope Ken at DPS has the stud issues worked out. Way back then he said they had a heat treat issue and thats why these studs failed....:dunno:angel:
