Idi powered 79' stepside recovery rig build
mudduck
davenport , iowa
Got almost all of the rear frame boxed in just have to start adding cross members
Neighbor kid thought it was a monster truck
Set the bed back on temporarily, looks much better with the frame at the correct lenght
mudduck
davenport , iowa
More pics of boxing the frame, its very time consuming but necessary.
The crossmembers in the rear are temporary just until i get the tubing i need
Got the front frame blasted and stripped down today
mudduck
davenport , iowa
Been awhile since i updated this but i just finished boxing the entire frame today.
That's amazing! Makes me feel ashamed of what I've done. I think I'm going to sell my stuff and just but one of those plastic new trucks. Well maybe not. I can have my stuff all showroom new for what it costs to buy a new one! Still, it's a great project!
mudduck
davenport , iowa
I could never go new, i love the old oddball trucks too much. Im also working on putting together a 78' bronco dd with a turbo'd 300 I6 4spd. And a legend/dwarf truck that i converted to four wheel drive with two transmissions, it will also be road legal in iowa
mudduck
davenport , iowa
Ive talked to some guys at work that bought new trucks that are almost double what my house cost! Theyre crazy
mudduck
davenport , iowa
This project is still alive to those following it, ive been working on it but havent posted up, sorry.the entire frame is now boxed and almost all of the crossmembers are in, i rebuilt the crossmembers for the bed and rear cab mounts, relocated the rest of the cab mounts, made solid engine mounts, bolted the c6 up to my idi and put it in the truck today
Greg5OH
MI
this thing is awesome. 79 is my favourite front end year.
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
That is quite the project, there is more engineering going on there than just an engine swap. I can't wait to see the end product perform. Good luck man.
mudduck
davenport , iowa
Got some more pics for you guys, transfer case is now mounted, incase you guy are wondering, engine,trans,and transfer case are all solid mounted.
First new thing is i notched the front of the frame for some 4"x1/4" wall square tubing to go in to relocate my front shackles, all together it gained me the 6" of lift i needed to get rid of the 6" block in the front axle.
All the gussets on it are 3/8"
And i am ordering new shackles that i am going to box in and plate.
Next thing i did was build some mounts for the tcase and get it in, the girlfriend even helped prep and sandblast it.
Mounts made
mudduck
davenport , iowa
Next thing i did was put a nice new straight front bezel on and convert the front end to tilt front, i really like the new front end!
Old front bezel
New front bezel
And the tilt front all done
mudduck
davenport , iowa
Got the blocks out of the front last night, the spring perches are 2 1/2" but i can live with that. Going to do the shackle flip on the rear axle tonight and build up the shackle mounts on both ends.
dirtbiker
Illinois
Cool build, I really like that tilt front end... You're giving me some crazy ideas for my 79. It's actually identical to yours except mine isn't a stepside. Short bed and 4x4 though, 6.9 powered but it's a t19 instead of a C6.
mudduck
davenport , iowa
I have wanted to go through with this project for years but never had enough motivation, my favorite trucks are late 70's fords and my favorite powerplant is the idi's. i think if ford would have had the idi motors in the 70's fords that they would have been the best looking and most reliable trucks ever made. So i had to make my own.
I am normally a fan of the manual trans and i did have a zf5 but i cracked the bellhousing when it was in my old truck, and an auto is going to benefit me more for what im doing, being able to shift gears without loosing wheel speed and boost is a huge gain for me, and if i can keep the c6 cool it will take a good beating.
