Idi injectors
Macrobb
North Idaho
Uh... I think you need to look at an injector diagram before thinking about something like this.
The injector only injects what the IP provides, and the limit of the injectors is /well/ beyond what any stock IP can put out.
Even a massive 180CC pump(which requires a massive turbo, intercooler, headstuds etc) doesn't need anything more than stock injectors to work.
Also, if your injectors aren't /perfectly/ balanced, they won't work right at all.
pelky350
Springfield, OR
View media item 154 r and d stage ones on right, bb code on left. Stage ones are a little larger injector option but precise machining, pressure testing and so forth goes into making them. Simply drilling the end out wouldn't do anything for you other than probably ruin the injector
HS108
Diesel Newb
Connecticut
You notice a big difference in the BB vs RD stg1
lewisstevey7
