all depends.
ive done it this way, and i ended up being 2 teeth off, lading me at -9 degrees.
it still fired and ran fine.
didnt have an issue with starting.
now if you advanced it 2 teeth, it could be the issue.
i would be pulling the timing gear cover and making sure you got the marks lined up.
with the IP still bolted to the housing and gear, run 2 5/16" bolts to "clamp" the gear through the IP bolt cover.
pull cover off without rotating the engine
(may want to pull the balancer first)
place IP gear cover back on and check marks.
if the marks line up,
take that craptastic vatozone stuff back and get another.
dont re-install cover without the new pump so you can to the same as above and get it correct every time.
