ConstantVigilance
I think I need to rebuild my Turbo again. I rebuilt it probably a year ago and maybe I did something wrong in the rebuild. It seemed pretty straightforward and simple.
If someone can take a listen on my test drive and hear what I'm hearing.
What noise is there that wasn't there before is a very high whine when I let off the fuel to shift gears.
There is also some vibrations that showed up simultaneously as the strange sounds from the turbo. The vibrations go away as soon as I start driving. When I checked my oil I was probably 2 quarts low at least. Then I noticed that I was spitting oil out of my exhaust. Not a lot but enough.
Also, there is a noise that seems to come from the turbo that wasn't there before that test run.
And then if anyone knows a good website where I could buy the entire kit. That is, the exhaust wheel the compressor wheel, and rebuild kit.
Also, if I should think about upgrading either of these wheels to something more efficient. Or are the wheels in these Banks turbo chargers tuned or specced out for these IDI's?
Lastly, please ignore the gruesome sounds from the steering column. I've been meaning to fix that. Just about got all the parts collected.
Sent from my SM-G930V using Tapatalk
