well i climbed under my truck the other day to see if i had any leaks and found three small drops of antifreeze on the starter. at first i thought that maybe the radiator had a small leak and the antifreeze was getting blown back towards the rear of the truck and somehow gathered on the starter. i looked all over the back of the engine where the heads meet the block and also checked the block heater and everything was dry except for a litle oil on the back the head. i dont see where it is coming from and its not much if it is leaking. i did a second observation today but this time with the engine running, this is how i found out that my 85 needed head gaskets. now for my findings i can see a little compression seeping out from between the heads and the block at the back of the engine. it is very little air bubbles that are showing up in the oil that has drained down the back of the engine where the heads meet the block. the funny thing is there are no signs of antifreeze coming out of the leak. at least with the 6.9 when the head gaskets where up for changing you could see the compression pushing small amounts of antifreeze out on every compression stroke. i wonder if i could buy me some time until after the winter months by doing a retorque on the head bolts? i doubt it though thats just the way my luck goes and i dont have the money to do it right now. what is yalls opinion on the retorque?
