I need E4od help ASAP!
OleBlue
Smoke Em If Ya Got
United States
Ok so let me give a little back ground I have a 1991 ford f-250 with the E4od 2wd with 199k. Ok so the past few weeks my trans has been shifting real funny. When I take off I have to let off the throttle to get it to shift from 1-2 then same on 2-3 but shifts fine 3-4. But lf running around 65 mph down the highway and give it anymore throttle it will down shift into 3rd let off and it shifts back into 4 th so on and so forth. Well I was driving home yesterday and I got home and went to shift into reverse and nothing. So I shifted into drive I had nothing. I can shift hears manually and have nothing at all. Fluid is not burnt it is still pink and smells fine.
aofarrell2
Turbo Desirous
IA
Is the MLPS aligned properly? Faulty MLPS sensors will do that. Replace it and align it, then check back again.
ntjapkes
