zrexryder
will they work and is this a good deal?
http://sacramento.craigslist.org/pts/1755014148.html
Actually this all depends on the pedal pushrod length - I have a Suburban hydroboost with the 2" too long pushrod and never had to mess with any pedal swaps, just shim the bottom of the plate a bit more than the top and tilt the whole unit back some 15 degrees or so. In that sense a GM hydro from a Burb or fullsize truck is a much easier install than the F-Superduty hydro with its pedal swap mess. Again tho it really depends on pushrod length, longer than the our factory vacuum booster rod is fine, but shorter would be a problem that's only solved with a welder...If you have an auto trans then you need the brake peddle. If you have a standard trans you need the clutch & brake peddle assembly. The auto trans brake peddle is easily removed after to remove a clip on the shaft. The standard trans peddle is way differant. Thats why you remove all of it....
Sure thing Rob, I did it in my driveway in just a few hours, and that's taking my sweet time playing with different pedal heights - basically the GM pushrod is 2-1/2" or so too long, so you have to make some sort of a spacer that is that thick to fit between the hydroboost mounting plate and the truck firewall, bolt patters are virtually the same tho so no drilling new holes is needed. By varying the overall thickness of that spacer you essentially adjust your pedal height (I ended up about an ninch higher than factory IIRC), and my having different thickness between the top and the bottom end you vary your pushrod angle. You can use pressure hoses for your year F-Superduty truck to make the whole thing work.
No pics of the spacer thing, can't see anything decent anyways but it's basically two pieces of 2"x1" square tubing shoved between the booster mounting plate and the firewall with some washers to shim the bottom end out a bit.
