how would you plumb this?
crash-harris
Breaker! Breaker!
Chillicothe, OH
Wouldn't a H pipe cause more heat via turbulence?
I would almost say plumb them individually. 1 turbo per bank, but I guess since the firing order doesn't bounce from side to side each time that it could cause some lag or balance issues. I like the U pipe idea with the smaller restrictor pipe between the 2 intakes.
Or put the X pipe between and towards the rear or the intakes, 180* bends around the back, over the valve covers and straight forward into the turbos. Effectively creates a 180* manifold and balances both banks, but would require more initial work and more work to remove if you needed to take a valve cover off. I'm assuming this is the engine that you have the fuel filter mounted on the fender with. That's the only way the 180* manifold would work, else it would hit the factory filter head.
sjwelds
Central KS
Don't super-built truck pulling engines and the like just use log style manifolds? Seems to me like the H pattern wouldn't affect performance much, if any. Plus IMO it would look cooler.
Too bad you aren't close to me; would love to TIG some things up for you LOL LOL
my charge clamps don't come in till tomorrow, so we got some time.
messed with it today after I plumbed my brakes.
this is what I came up with.
hope my clamps come tomorrow and I can finish it.
I had to raise the "chamber to get away from the throttle linkage.
it will do fine for now
heres the design I came up with.
my TIG welding sucks.
but it seals!
pelky350
Springfield, OR
Is it gonna be running soon?? Dying to hear this been watching the thread for some time now, excellent work!
FoolhardyIDI
Arizona
If you were to do an x pipe I would think something like this would be a good way to go.
