AutoRx vs. Kreen
I have no doubt that the Kreen does wonders. I've used plenty of fast flushes in the past, since I've been selling synthetics for about 34 years now and flushing before changing has been a mainstay of proper changover procedures from the start, but I quit using any kind of fast flush a long time ago and strictly use the Auto Rx now, because any and all fast flushes can knock large chunks loose and block an oil passage or scratch the heck out of a bearing ( after personally having had to tear an engine apart to repair the damage from a fast flush, this isn't just hearsay ) and I have yet to see any fast flush that will come close to doing what Auto Rx will do.
I believe both products do a good job...I would like to say that I researched both products before I settled on Kreen...Here's how I made up my mind as to which one to use...And I hope anyone out there thinking of flushing their engine go thru the same or similar process before they buy one or the other...
First...We know AutoRx is generally considered a "safer but slower" process...Second...We know Kreen is a "faster but possibly riskier" process...
Knowing how each works...I next took into consideration the mileage of my engine, its symptoms, and its overall condition...ie...does it need a new IP & injectors or soon will need? Is the coolant system in good shape? See where I am going...
Next...If I use Kreen and I lose the engine...Am I prepared to overhaul or buy used and drop it in and go on...How much work am I willing to do? Money? Etc..Etc...
My conclusion...I elected to go with Kreen because of high mileage and if the results are successful it would be fast and least costly and least work...If it failed I was prepared to buy a used engine...because I had a new radiator, water pump, thermostat, all new belts and hoses, recent oil cooler re-seal...all these could be put on "new" used engine...So, I was willing to risk it...
If I would have had a much lower mileage engine...I would have gone with AutoRx to try and wake her back up...So for me the mileage really was the deciding factor thinking I really didn't have that much to lose...As is turned out...everything went well and my hope is the engine will last long enough for me to continue to save money and buy parts for a complete overhaul later down the road...
Why stick with the 6.9 and completely overhaul in the future? Well I have one of the blocks that is considered one of the best blocks of all that were cast according to serial number etc...Plus the block is beefy all around, easy to work on, and just plain simple...even with a turbo...and at my age should last till I die...
Well those are my thoughts...just saying
