IHdieselfan
I have a friends 92 f350 that I have been working on. H e brought it to me to do a lot of stuff to it brakes, cooling system mainly, but complained a little about not starting hot. Truck has 139, 000 mi. On it and pretty well maintained. I had the injection pump rebuilt at 80, 000. That time it had the same hot start problems. I removed the pump again and carried it back to the same pump shop had them test it said it had high return again. So they built it again. Put it back on still hot start problem. To define, when warm if you shut it down and in 30 sec crank it up again it fires ok, but if you let it sit for 15 to 20 min and try to crank it, it spins a lot before it runs. And it doesn't mattet if you give it some throttle or not and doesn't matter if you use the glow plugs. Now I've talked back with pump shop they said bring the injectors and they would pop test them. Did that and I watched they popped off at 2000 but not the best pattern and leaked a stream off just below that pressure. He sold me a new set of injectors. Installed them with the exact same results. Now with all that said understand that I have been doing business with this place for a long time. Me and my dad graded the building pad were the currently are located. But have found that they are not as good as they think they are sometimes. And have found that on somethings i know more than they do. Now anybody seen this before or know what to check next. Also starts cold perfect. But on another note I don't think he's been putting lubricant in the fuel either.
