Before you dismantle your steering wheel looking for a switch problem, check your cruise control module. The horn is grounded through the cc module for some reason.
IIRC, that's because they only have 3 wires(2 slip rings and ground) going into the steering wheel, and they are used for 5 cc buttons and the horn button.
each wire is doing several functions using various resistances between the wires.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
