Happy New Year everyone, I need some advise regarding my fuel return line job i'm doing. So my truck is a '92 F350 CCLB SRW 4x4 with the 7.3. I have the brass T at cylinder 8 and it has hose running from it, to under the truck. My problem is, is that I tried to take off that hose to replace it lake all the rest because all my hoses were brittle as kindling and I figured once into the job might as well do all the old hose. I can't get the old hose off the T fitting, and i'm not sure where it leads to. It seems to press onto a steel line from the tanks. I currently have to full tanks and do not want to pull a line and start shooting Diesel all over the place.
I've chewed up the end of the hose on the T fitting trying to take it off (I know, i did not think this through..) and i don't know if I can go back and re-clamp it and be okay. Maybe cutting the old hose and splicing in a brass fitting and new hose?
Should I push to replace ALL the old hose? Is it worth it?
I gotta say, I've been lurking here for awhile before and after I bought my truck. This is the BEST site out of a couple for anything IDI related. I would not be confident enough to replace my own GP's, Injectors and return lines taking the time to do it right with the right stuff. Viton rings and Viton fuel line, without this site. THANKS!
