gingrass179
ok guys so since last February I have been sourcing parts and getting machining done slowly and surely...well I am now to the point of assembly and ring end gaps will be the purpose of this post
ok so this is an 87 6.9 block that was bored .040 over and that was just enough to get the taper out of the cylinders
the specs in my book say
6.9
top ring: .014-.024
2nd ring: .060-.070
oil control ring: .010-.024
7.3
top ring: .013-.045
2nd ring: .060-.085
oil control ring: not available (that's what it says in my Haynes Diesel techbook for the 5.7, 6.2 6.5GM and 6.9 and 7.3 Ford)
here are my ring end gap measurements
Cyl1
Top: .020
2nd: .078
Oil: .035
Cyl2
Top: .022
2nd: .077
Oil: .035
Cyl3
Top: .022
2nd: .080
Oil: .035
Cyl4
Top: .023
2nd: .078
Oil: .036
Cyl5
Top: .022
2nd: .079
Oil: .038
Cyl6
Top: .024
2nd: .077
Oil: .038
Cyl7
Top: .023
2nd: .080
Oil: .036
Cyl8
Top: .024
2nd: .078
Oil: .035
So obviously as seen here the top compression ring is at the top of its tolerance
the 2nd compression ring is about .010 more than spec
and the oil is also .010 more than spec
This stuff just came back from the machine shop how come nothing is adding up?
I have been reading and as cylinder size goes up ring end gap goes up...but how much extra ring end gap would I need by going up .040 in cylinder size?
also my mains are right at the top of there tolerances...
I have right at 5,000 into this engine so far between the balancing new bearings pistons rings head job cam injectors lifters pushrods head and main studs etc everything is new! so I don't want to take any chances with this thing..
Trying to see what the community thinks about these numbers
Thanks for any input guys!
6.9
top ring: .014-.024
2nd ring: .060-.070
7.3
top ring: .013-.045
2nd ring: .060-.085
Cyl1
Top: .020
2nd: .078
Oil: .035
Cyl2
Top: .022
2nd: .077
Oil: .035
Cyl3
Top: .022
2nd: .080
Oil: .035
Cyl4
Top: .023
2nd: .078
Oil: .036
Cyl5
Top: .022
2nd: .079
Oil: .038
Cyl6
Top: .024
2nd: .077
Oil: .038
Cyl7
Top: .023
2nd: .080
Oil: .036
Cyl8
Top: .024
2nd: .078
Oil: .035
