My truck recently started having a problem and I'm not sure what it could be. When I shift into any gear and let out the clutch, there is a grinding noise and it stops when I push the clutch back in. Then if I let the truck idle down it goes in fine. And it shifts into gear fine without grinding. It only grinds when letting out the clutch. And it only does this half the time. What could be the problem?
