Help ASAP! What is this part?????
The Warden
MiB Impersonator
Fog Bless Pacifica (CA)
FWIW, I think that all trucks except regular cab 4x4's (and MAYBE regular cab 4x2's, but I recall someone with a 4x2 regular cab saying he had one) have a carrier bearing. I know I have one on my 4x4 extended-cab.
Real easy to replace...just take the driveshaft to your friendly neighborhood machine shop, ask them to press out the old one and install the new one, and $10 or so later, you're good to go! :D
krawlr
Yup, that's me
Cincinnati, OH
My Ingersol couldn't even get the big nut loose. I didn't think there was anything "Inga" couldn't get loose.:eek:
tonkadoctor
none ya bidnes
OK,How do you remove and Replace the bearing assembly?Any special tools needed?
  1. Torch-Flame Thr
  2. Good skills with torch or don't even try it;Sweet
  3. BFH:smash:
  4. Big hydraulic press preffered:love:
  5. Expanded vocabulary-cuss
  6. Pockets deep enough to take it to the shop when you give up:hail
:D
I ain't never gonna do that job myself again
160k87F250
not rocket science
York, PA
Both my trucks have them, and I've had to replace both of them. Not a big deal, but of course, I did them at work with air tools and a press. I shimmed my 2wd bearing when I put a slight lift on the truck. No ill effects.
Tanya, that bearing should of been making some noise before it turned into that!!!
John
Exekiel69
I did the one on My truck and it sure was a lot of work with no tools but it was not impossible, just have a good chissel and 2 lbs hammer and a good pair of gloves that will do the trick if You don't know any drive shaft shop.
Double-S-Diesel
parts seller
derry pa
at the first IDI ralley, I think it took 10 or so of us, A big hammer, a picinic table, and a piece of pipe from somewhere and we changed one.
tonkadoctor
none ya bidnes
Ummmmm Lemme venture a guess here.....The picnic table was for the 9 supevisors and the cooler.;Sweet
:drunk: :drunk: :drunk: :drunk: :drunk: :drunk: :drunk: :cheers:
f-two-fiddy
Duluth, Mn.
Ron,
Go ahead and shim it if it makes you feel better - it won't hurt anything...
Your prolly better off shimming it, to get a good driveline angle. Less wear.
Take a look at the Monster trucks. They use big steel brackets to straighten theirs out.
ntjapkes
