bignastystacks
When I first started using the heater this winter it was making a squealing noise at start up. That stopped about the second day of using the heater. Then out of no where the fan stopped blowing all together. Then the fan would randomly work but it was blowing all cold air no heat at all. Well now its stopped working all together. Fuses are fine. I thought I would see if anyone has experienced this same issue before r&r (remove and replace). My ac pump took a **** this summer so I now have the bypass pully in. Not sure if its related???
