is just the cloth itself falling down? if it is sand all the foam off and get some of the headliner material from the dealer or some car place ziebart and some adhesive and get it done
My liner is falling as well. SO I was under the impression that the headliners were material bonded to a layer of foam bonded to some sort of backer board. Is that the case?
ya you have the right idea, when the glue is old and something touches the headliner the bond breaks the the headliner falls. An upolstery place should have what you need
you use the spray but the foam and material is all one piece. Did it to mine but we got the headliner stuff for free. It does not look as good as if you took it somewhere but it is cheaper and you can it to your jack of all traits list
