6.9man
ok i am planning on sticking head studs in. but im wondering if you stick them in without actually taking the head off if you take 1 bolt out at a time and stick stud in and tighten down to 70 pounds and do the rest the same way and then tighten all down to whatever they can take after there all in. if that work?
the only reason i dont wanna pull the heads is afraid of warping but can you mill anything off these to resurface them without shaving the pistons too if there warped? whats the chances they be warped? when i got it and pulled with it i couldn't get the pyrometer over 1000 egts going up hill pulling load of cows so i dont think its ever been run real hot to warp them bad but never know what the guy did before i got it. and i have heard felpro head gaskets are the best to use is that true? i just wanna to get to where i dont ever gotta worry about running to much boost to blow head gasket and wouldn't mind being able to run more boost too. im just trying to figure out what i will have to do to it to before i tear into it and what im to expect to find? thanks
