the turning radius alone is what sold me.
They're rare, but SuperCab F-350's DID exist. I know a guy who used to have a '91 F-350 SC DRW that he bought new and kept in factory condition...it was a creampuff even at 300K+ miles when the engine cavitated.Yep, never understood why they didn't make a SuperCab F-350 as the difference is just bolt on suspension parts from what I understand. I swapped a D60 under my SuperCab. Have a CrewCab now but definitely prefer Supercab.
mel's CC dually has the same setup too.I have a Gear Vendors with an adapter that makes it mount in place of the carrier bearing. It doesn't bolt to the transmission or transfer case.
Seems I may have the only "divorced" GV unit in existence, since I've never seen another like it. Talked to GV when I bought it some years ago.. they acknowledged they made them. Offered to "buy it in exchange" .. I said no.. tyvm.
Requires building a bracket to mount in place of the carrier bearing, with a lot of attention paid to angle of mounting, AND cutting both driveshafts. I can see why few have used that application..
tim-They're rare, but SuperCab F-350's DID exist. I know a guy who used to have a '91 F-350 SC DRW that he bought new and kept in factory condition...it was a creampuff even at 300K+ miles when the engine cavitated.
No pictures of that truck, unfortuantely, but I found a few pics of OBS SC DRW's...
However, they weren't common, and I don't think I've ever seen an SC F-350 with four wheel drive...or, for that matter, I can't recall ever seeing a SC F-350 that was a SRW. I would guess that anyone who wanted an SRW SC truck was pushed to the F-250, and of course you couldn't get a 4x4 DRW unless you got a chassis-cab truck, or built one like towcat did
{on edit} Found a brick-nose SC DRW
Maybe I misunderstood dunk's post, but I had the impression he was trying to say that SC F-350's didn't exist at all, even in 2WD form. Hence my responsetim-
2wd SC F350's are quite plentiful due to DOT regs. it's the D60 equiped SC 4x4's are the ones ford never made.
No...I think the DOT regulations towcat mentioned were referring to overall combination length i.e. a SC truck would be better if you're pulling a long trailer, because the truck itself is shorter and you can get away with a longer trailer before Smokey Bear decides to have a chat with you.ohh so the reason ford didnt put the bigger better axle in the SC was because of DOT regs?
i have a rule of thumb when it comes to loaning out my stuff. If the borrower doesn't have the means to repair or replace, they don't borrow my stuff then. Truck is mime. It's a "frankenstien" of sorts. Ford should have built a SC 4x4 with a D60 front, but they didn't. I did. It gets worked hard. in fact, I need to replace the cab in the next month or so due to the right side getting taco'd really bad on a large rock. At least the frame didn't get hurt.
here's a couple more pics of the "Sulaco". as you can see in the interior, it's optimized for cargo hauling.
I wonder if a person could use a this style of gear vendors between the trans and transfercase.
