PwrSmoke
Yeah, I agree. That filter efficiency improves with use is a fact that isn't trumped by misinterpreted observations (no insult intended Devon ( : < ). Most likely, Devon, by changing the filter early... and those filters hold two quarts.... you are putting in 2 plus quarts of fresh, clean oil which will dilute the normally black color of diesel oil. You are doing a 20 percent oil change essentially. Take a cup of iced tea brewed dark and strong like I love it. Increase the volume of it with 20 percent water and see how much clearer the tea gets.
The color of oil, especially in a diesel... most especially an old school diesel like an IDI... is of minimal importance. The black is soot and an older, more tired engine will generate more of it. Thing is, it's mostly sub-micronic... meaning it's smaller than a micron in size. Now it can agglomerate (clump together) and make bigger particles when the dispersant and detergent additives in the oil wear out, but when dispersed it's relatively harmless to the engine and flows through all the but the finest filtration systems. If fact, I've been told that when you have a diesel engine in which the oil stays too clean looking too long, it's either not running or it has one heck of a bypass filtration system in it.
