Sadly Motorcraft Batteries don't have date tabs anymore, you need the original purchase receipt to get them warrantied.
Isn't there at least a criptic looking sticker on the side somewhere or a brand burned into the plastic with a code? looky here
I hate to tell you but what you bought is called trash
Im not insulting you im joking around but all jokes aside wal-mart batteries are just cheap and they dont last long i have never been able to keep one much over a year,
The G-31's are awesome
You don't have to be the original purchaser on batts to have them covered under warranty . if teh month year tabs were plucked out at time of sale they will be warranted from that date and if not they will go by the manufacture date stamp which may be a number of months or a year older than when you bought it so you'll loose out on warranty so you always want to make sure the tabs are pulled, but if it's over 2 years old the prorate on the thing will be to where you might as well just get better batts, because they will prorate them down so far after that to where you end up paying for most of the new one anyway and 850 amps is min for these things, a nice set of 31s batts would get you usually 1000 min, Mine have 1150 ea that I got at Truck Pro for under a hundred bucks ea.
Its a everstart maxx-65n I don't know if I would call it junk its started my truck w/ bad plugs below zero not plugged in. Definitely not a great battery as I just read some reviews where people have had them die after 6 months. I have had these for almost 2 years now. I really don't know what to compare them to I could be missing out on the group 31s and if they die I will look into that. I guess its not 1000 cca its 850 cca and 1000 ca. It appears they have a 3 year free replacement. I think after that they degrade the price somewhat and you have to pay the difference. I had a battery from Oreillys once that they did that after several years it still had a few dollars worth of warranty towards the next one. My dad had a wal-mart battery in his wood truck that is severely abused and wasn't even the right battery. We couldn't get it to start one day so narrowed it down to the battery. We took it in and tested it showed good and we was about to leave. Then I said try the side terminals thats where we have it hooked to so they did. It was bad on the side. They looked up by application the correct battery for his truck and gave it to him for free and it was a more expensive battery than what he brought in. They goofed I am sure but its been in his truck for several years since then. How much do the group 31s cost and wheres a good place to get them? TSC?
With my swap i moved the passenger side battery tray to the drivers side so that they are right next to each other. I also just got done making bran new battery cables with the good solder on ends. I would love to get a set of group 31s but i dont know how they will fit in my configuration. I have access to interstate MG-65s or something rather for 88 each..
This is something I would LOVE to do. Move the driver side battery to the passenger side and throw two 31's at it. It would take some work, but to be able send the starter flying across a parking lot after it broke free from the truck from the starter torque at -40*F is something I would LOVE to do.
No more boosting.....EVER!!
FWIW I hear that 31's are cheaper than 65's, and have WAY more capacity!!
Anyone successfully put 31's in a 92 and up truck?
What all would I have to move to get two 31's on the passenger side? I would have LOTS of room, just gotta move things around.
Just take out the factory jack and rig a mount.
If you haven't already done anythine else there, not much. Just take out the factory jack and rig a mount. I've seen a few cases of guys rigging a third batt there just to run the glow plugs off and keep that separate from the starting batts
How could one go about doing that? I've got two more group 31's sitting here, although one is powering my CB linear in the house lol.
