Got my exhaust on
OK... I need 3.5 though...... the rest of the system is going to stay stock size...... just a couple "things" in the middle that look like they are about ready to "fall out"....... Still TruckPro?
i got mine at the electrical store, 10' of 4.5"( 4" conduit so called)
and a 90* bend for 65 bucks.
and its galvanized!
laserjock
Almost there...
A word on galvanized pipe. Galvanized is zinc plated. Zinc plating doesn't like heat. It might be sorta okay down stream but up where the exhaust is hot, it will burn the zinc off and rot eventually.
laserjock
Almost there...
Not saying it won't last a good while because conduit is pretty thick but I don't think it will last like aluminized or stainless tubing.
This is a cautionary note about welding zink plated parts. Don't do it. The burned gas coming off the welding will kill you. There are osha codes about welding zink too. Just read up on them. Best I can tell you is grind off the zink before welding. An additional note about zink is welding it will make a very porous weld full of pin holes. Also if you wash parts before welding with brakclean then you are really in trouble with poisonous gas. Even though it will leave no film behind and is a terrific cleaner what is left behind turns deadly when heated during welding. Now don't be afraid but be careful welding.
nothing is better than SS, but it is better than mild steel! sure it will eventually rust, but for the price, it cant be beat!
jhenegh
Truck Still Earns its Keep
Deerfield, WI
@jhenegh
Do you remember where you got the straight section originally? I am looking to get about 10' of 3.5" and 2 band clamps. I have a couple of "things" in the exhaust I would like to eliminate......... but want to use the band clamps, so I can easily make changed if I so choose.......
I was thinking maybe TruckPro down here in Indy, unless you know of somewhere that is less expensive.
http://www.amazon.com/gp/product/B009TOIO0G?refRID=XJCB93VVB3WWRH5CP22V&ref_=ya_st_pd_dx_wl_3
