How can you tell looking at it that it's a gasser tranny?
why do all these deals have to be so far away!
There is a guy by me that has 2-3 460 Zfs for $250 a piece
Not the transmission, but the plate that is behind the clutch in the photo. That thin tin plate goes between the block and the transmission and acts as a dust cover for the bottom of the clutch/flywheel on 460 engines. On a diesel, there is the thick trans adaptor plate only. The diesel also uses a small dust cover that bolts the to the tranmission and the transmission adaptor plate.
On Edit: If you there was a photo fo the behousing pattern, you can tell the difference there as well.
Heath
Are they 4WD Zf's though?
Or you can tell by calling and asking.
Silverburner,,,,a 460 ZF can work on a diesel, but it has to be drilled/modified.
There is a recent post, it's more than I want to do or have tools for, but you may have access to what's needed at work.
