Good deal for a ZF
plywood
Recovered N/A
Portland Oregon
That's a 460 setup.
If someone wants one of those, I located one for either $100 or $200, can't remember now, but something else came up I couldn't pass on. I might be able to figure out what number was his on my phone. It is a 460 tranny only out in Forest Grove.
hesutton
The Anti-Anderson
Bowling Green, KY
How can you tell looking at it that it's a gasser tranny?
Not the transmission, but the plate that is behind the clutch in the photo. That thin tin plate goes between the block and the transmission and acts as a dust cover for the bottom of the clutch/flywheel on 460 engines. On a diesel, there is the thick trans adaptor plate only. The diesel also uses a small dust cover that bolts the to the tranmission and the transmission adaptor plate.
On Edit: If there was a photo fo the behousing pattern, you can tell the difference there as well.
Heath
plywood
Recovered N/A
Portland Oregon
On Edit: If you there was a photo fo the behousing pattern, you can tell the difference there as well.
Heath
Or you can tell by calling and asking.LOL
Silverburner,,,,a 460 ZF can work on a diesel, but it has to be drilled/modified.
There is a recent post, it's more than I want to do or have tools for, but you may have access to what's needed at work.
Silver Burner
Burnin' Oil&Rubber
Beaverton, OR
Yeah I know. I couldn't tell looking at it whether or not it was a 460 or diesel tranny, but I wouldn't have posted if I didn't know that the tranny could work with our trucks, even if it did require a little "typ4" modification. :D
plywood
Recovered N/A
Portland Oregon
I happened to have talked to him already.
He seem like a good guy, the ad before indicated it was a 460, then I think he figured out it was called a ZF and changed some stuff.
MadScientist
