I like those wheels/tires in the front. I'd toss the head rack and call it a day.
My guess would be the same. I'd start with the glow plugs. That's what I did when I got my truck. Do you know when or if the IP/Injectors have been rebuilt or replaced?
I'm not sure and nether does the kid I'm getting it from I do know the turbo is less then a year old he went out one morning it died he said when it's cranks getting lots of white smoke just won't fire
I'd guess definitely glow plugs for the initial starting issue. Could be controller or relay too but if it starts plugged in and only white smoke without plugging in then something is causing the glow plugs not to work.
Will it fire and stay running after it stalls out the first time?
When you say spray are you referring to starting fluid? If so, NEVER use starting fluid while glow plugs are operational. Even though you stated they may not be working if you aren't 100% sure I wouldn't be using the spray.
How much fuel does it have? I know mine has the typical "runs out at 1/4 tank" problem. If you're too low on fuel that "could" have something to do with it.
