GLow Plugs
osus86diesel
Troy, Ohio
I purchased new glow plugs today and was wondering if anyone had used champion glow plugs from Napa and if there is anything I need to watch out for with them. Should I return them and get something else or will I be okay with these?
Thanks guys!
GenLightening
Yeah, it's a CHEVY!
Pukalani, Hawaii
Don't put them in your engine! They tend to swell and break (if they don't burn out first)which will ruin your year. Take them back and look for Beru/Motorcraft. You'll probably have to get them online.
CDX825
filtration nut
Litchfield,Ohio
What he said! Also watch pulling the old ones out. If they are anything besides Beru/Motorcraft you may have problems.
david85
Campbell River, B.C.
What they said. DON'T USE THEM!!!!
Don't even take them out of the box.
Use the block heater to cold start it until you can get good beru/motorcraft glow plugs.
vmax3_2001
topeka ks
Hey man, go to Ryder Fleet Products and get yourself some ZD9 motorcraft plugs, they are fairly inexpensive I paid $10.83 a piece, not a bad price. The only problem I had was they back ordered them so I had to yell at the service rep to get the supplier to ship them to me. P# W83ZD9
If you have a IH truck dealer near you, they have the ZD9 motorcraft. At leaste they do in Lima .
osus86diesel
Troy, Ohio
Thanks guys! I will head over to the other side of Columbus tomorrow to the international truck shop. I guess convenience isn't always the best answer....
Champion :puke:
Autolite :puke:
:puke: :puke: :puke: There's a long list of inadequate plugs. Beru is best. Period.
BigRigTech
Diesel junky
Nova Scotia, Canada
I got a bill for 2 Beru's I order through work from my local IH dealer....$63 for two!!!...I just about **** then I was pissed....I paid $42 for 2 last time but the Ford dealers want even more....
howards@howard
Byfield MA
bad glow plugs
On a 1989 7.3 IDI as a maintenance procedure on a perfectly good running truck I put in 8 new accurate diesel glow plugs. after one day the truck no start 30 degrees outside. I put in new relay thinking that the new plugs may have did it in still no start. I checked the plugs 5 out of the 8 new plugs no good. What do you figure happened?
I smashed open the old relay it was worn out but not welded. Who makes a good relay maybe like the gas filled ones on the PSD's? Should I suspect the controller too???
howards@howard
Byfield MA
The glow plugs are made for Accurate diesel and sold by them. Go to there web site. They were recommended from this Forum. They calm to be the highest quality. I don't think they are the problem. I have been doing this my whole life and I have never seen a controller burn out a whole set of brand new plugs.
m2rtin
Staff online
