Glow plug power wire
dsblack
Washington State
Ok, In the plug where the wires go onto the engine, which wire supplies the power for the GP's
And is there a part # that anyone knows for this connector?
thanks
Doug
geonc
SPIDER BAIT
NECKVILLE North Carolina
In the FWIW dept :D there should be 2 yellowish 12/10 ga wires that start at the fender relay and feed the GP relay...via the cannon type plug on the right fender.....if yours are burned/jacket soft from heat....you can eliminate them ;Sweet
Just get some 4 ga wire,
couple solder lugs....ones that fit the 5/16" studs on both relay posts---solder and heat shrink the ends and replace that whimpy wiring :puke:
If you feel the need for protection, you can get a 250 amp mega fuse and fuse block ---from NAPA for about $25 {:sorry: I cannot recall the part #s...been a few weeks ago LOL}
I ran this set up on my '90 IDI for 4 years at 700 mi a week and never looked back :hail ...without a fuse :D
Hope this can be of some help :cheers:
typ4
Newberg,OR
You cant get the connector from ford anymore unless they have some old stock, I got to have the good fortune of finding a perfect harness in a yard.
I would bypass the original , that many amps dont like that kind of terminal, this is a chronic problem with our trucks.
m2rtin
