Pianoman
Hi, all! I've got an 86 F250 6.9. Low miles, just over 100k, T19, stock as they come, except for the manual glow plug conversion. The truck had some issues when I bought it, one being that the glow plugs were out. New Berus, and it fired right up when cold. About 10 times. Then nothing. No problem! How about new AC Delco 12G or whatever those were! No problem. Fired right up when cold. About 25 times. These went bad more slowly, maybe because I was paying closer attention. Now, a set from somewhere or another, Wellmans apparently. These are also starting to fail. I've reduced my glow times to 5 sec max, but this doesn't seem to be making a difference. Cold starts get harder each time. A TINY shot of ether into the top of the snorkel lights it up with no fuss every time (no glow for this of course....)
Any ideas?
My pal wrenches on his Benzs, and he thought the plugs should be clean after being in use. Mine come out sooty pretty fast. I thought maybe I need new injectors? IP has only 30k, O rings were done on the injectors, but they are probably OG, with 116k on them now.
This is my hauler, not my commuter, but I need it for LONG trips when the time comes.....
Any ideas?
